JCL
- May 30, 2013
- 42
- 9
- 8
- Location
- Monbulk, VIC
- VS V6 Ute
VS V6 ute.
I didnt drive it for about 6 weeks and then it started misfiring and spluttering on idle and any sort of load. It needed a full service and some things done so i took the opportunity to change the inlet manifold gaskets to Mace ones, replaced all fluids and filters, changed all the vacuum hoses and just today replaced the crank angle sensor and swapped over the DFI module.
Still having the 2 error codes show up and all of the misfiring, rough idle.
Next steps will be to change all the plugs, leads and coil packs and maybe try and clean out the throttle body but my question is - if the CAS is a brand new delphi and the DFI module is new - what other causes could result in codes 47 and 49 which should be ignition related to the CAS or DFI module as far as I am aware.
Leads and plugs are about 12 months old but ive never replaced the coil packs in my time with the car ~ 3 years.
I think I have read every thread on here about CAS or the above error codes but still feeling a little lost.
Any ideas?
Any ideas?
