Starr Manifold and LS1 TB's Interchangeable?
Dan355
Go THE SS's
Street Legal 355ci VN SS - Daily: VP SS
Hey,
Just wondering if LS1 TB's can be bolted on to Starr manifolds for the 5ltr? There 90mm in size but not sure what type of TB they are?
Ive found an induction hat for high rise manifolds that accepts LS1 TB's but just wondering if i can bolt the Starr manifold TB to that rather than buying a LS1 TB.
Cheers!
apoc585
Hawkesbury
VS Maloo
Ok, if i understand this right, your talking about the snorkel that bolts to the top of the manifold(similar to t/p etc) and bends forwards to a round hole to bolt a TB onto? If it is then the answer (im fairly sure) is no. the ones i have seen have the T/B end of the snorkel to suit an LS1 throttle body only.
Hope this is wat u were after. If not, then sorry for useless post:p haha
Dan355
Go THE SS's
Thats right but i wanna know if theres much difference between my tb and the ls1 tb.
apoc585
Hawkesbury
VS Maloo
from wat i know the ls1 t/b's bolt onto a square flange whereas 5L ones are round. i think thats the only difference...
otherwise get a mate with an LS1 and take a look at the 2:)
let us know if ya find out for sure
Dan355
Go THE SS's
The starr tb has a square flange as well. Ill have a look at my mates tb over the weekend.
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
since i have no access to one can you tell me if there is enuff vacume ports and if they have a idle control valve and if a tps will bolt up to one off the 5l
