edals
Hi Guys.
Need to install a replacement steering rack on my V6 Wagon. Inner Tie rods are worn and the rack is also leaking.
From what i can tell its as follows.
Raise Car, Remove wheels.
Remove the spilt pins, remove the tie rod nuts, Bash out the tie rod ends. (I too will replace these)
Undo the hi and low pressure lines (understand these can be tricky to undo, I also have pipe spanners)
Undo the bolt holding the uni joint to the steering rack shaft then slide it up.
Undo the 2 mounting bolts and pull out the rack.
Install in reverse, is the best option to ensure the wheels are straight and steering wheel is straight before re-attacthing the uni joint to the rack shaft for close alignment ? looks like the rack has a flat side of the shaft so guessing it lines up pretty well.
and obviously refill and bleed the system, then a wheel alignment.
Any other tips or tricks people know about i may run into ?
Cheers.
Cheers.
