so all i need to do is buy the new engine from c.o.m.e put that in
rebuild the gear box
do the lsd
put stallie in
and they tow it to get dyno?tune.. will it be drive able when he rebuild gearbox and new motor goes in it .. and does the gear box gear ratio need tobe changed? and the diffs .. but when i put the dif in a can not drive it that right?
ok, the stallie is essentially a higher rpm torque converter, which is part of the transmission and will be taken care of when the trans is rebuilt.
the reason i say you'd tow it to a dyno tuner is simply because the engine wont run very well at all on a stock tune once the new stroker engine is put in. it might start and run, but probably wouldnt be advisable to drive.
if you were to buy the complete engine ($9k) from c.o.m.e. that comes with the tune you would need and the engine is already run-in on the dyno.
not sure what you mean by transmission ratio needing to be changed, just forget about that.
the diff swap would not affect you being able to drive the car, the only thing needed to get the car running properly once all parts are changed (engine, trans and diff) is a suitable tune.
if you were to get a different gear ratio for the diff - say 3.7, your speedo would be inacurate, but the car would be perfectly drivable.
