stupid bolt
HQPremier
58
Seaford
95 statesman 72 HQ premier
how stupid is the rear rocker cover bolt on the drivers side v8 vs statesman.
in below brake booster how the F@#$ do You get that one in?
BlackVXGTS
Melbourne, SE
You need a long flexible driver and (preferably) small hands. Attach a socket that's the correct size for the bolt head to the flexible driver, part fill the socket with blue tack or similar and insert the bolt head into the socket. Reach around underneath with your left hand until you are near the bolt hole in the rocker cover, insert the flexible drive/bolt from the top with your right hand and guide it into the hole with your left hand.
Tighten it down and hope you never have to do it again!!!
Other forum members may have better methods.
vc commodore
Like the Leyland Brothers
VC, VH and VY
I have put threaded rod in the bolt holes of my rocker cover and use nuts and washers to tighten it down.
Find it easier keeping the gasket in situ and saves swearing trying to find the hole to start the bolt....
Food for thought :)
  • Like
Reactions: Lex
