Stupidly high idle NEED HELP ASAP
Vys.pac
19
Vy sv6
Hi I need help with my 2002 VY s pac manual Ute, I start the car and it revs it about 1000rpm then just keep increasing and sometimes sits around 3000 RPM and when revved (not in gear) it gets stuck around 2500 to 3000 rpm it’s chewing through fuel also. I’m all out of ideas and this is my only car to get to work.
- The cable has small amount of slack
- The TPS and IAC sensors have been replaced
Immortality
Staff member
Sth Auck, NZ
Did you replace the TPS and IAC before or after this problem occurred?
ephect
Donating Member
VS Acclaim V6
Sounds like a vac leak around the throttlebody.
As Immortality asked, did you have the issue before you replaced the 2 sensors or after.
Illjamz
21
Kaitaia
Vy s commodore
Hey bro did u end up figuring out what was wrong I’m having the same problem and have changed both sensors
Vys.pac
19
Vy sv6
I only replaced the sensors because of the issue
Vys.pac
19
Vy sv6
Nah I’ve replaced throttle body, sensors, maf sensor everything I’m lost dunno what to do
Immortality
Staff member
Sth Auck, NZ
have you changed or adjusted the throttle body at all?
Any other modifications?
mindedrobin
24
Australia
VY Commodore Executive Series II
I had a high idle on my VY series 2 at 2500 - 3000 rpm in neutral and I had the replaces the IAC twice as the first replacement was a dodgy one, so i would recommend trying to replace the IAC a second time and as others said check for vacuum leaks.
BlackVXGTS
Melbourne, SE
The accelerator cable needs to have 10-15mm of play. Too tight and you will get the symptoms you are experiencing.
