As above. It can be done if keeping low boost as said.
Torque converter is different, ecotec is 1800 stall and super 6 is 2600. Also I believe the physical dimensions are different too, but not sure about that.
The ecotec bottom end will take a bit mroe than standard boost if tuned correctly! "Tuned correctly" being the operative!
If it isn't then as Deek said, bye bye.. lol
If you are keen for a conversion though I have a few things I need to get rid of. They are in the forsale section.
If you want good advise, give either Blue chip or Yella Terra a call. YT may just have the solution you require....
