Were the dampers also replaced ? Or was it just springs ?Just had my rsv lowered looks great rides flatter rides great.used king springs.i believe pedders also make springs to suit.
Stock shocks are not a problem however the ride becomes harsh so harsh in fact I went back to the stock springs.the bloke at king springs said why did you lower it the rsv and vxr are set up perfectly from stock.the ride became so bad I thought the car would shake to bits.the springs were 35% stiffer it just ruined a good ride.just my oppinion but I wouldn't recommend lowering I'm sure others will have a different oppinion. 1 1/4 lower looked good.How much lower ? are the stock dampers coping with the increased spring rate ?
