Svs reset not going away
Vtllcommodore
VT s2 berlina
Hey all got a 05 vz sv8 have changed over purge solenoid at engine started car all fine today I drove it when it got warm reset light has come up I took disconnected battery reset comes back up when I start the car I tried to reset but it's all serviced I have put original fuel purge solenoid back in and still doing it? I heard people say it can be a oil pressure sensor and be picked up on the tech 2? I have no codes on the car.
Drawnnite
Obviously Unsensible
2000 Vs Ute
SVS alarms wont pick up on a normal OBD2 scan tool.
Will need a tech 2 to know what it is.
However commonly it is known that it is the oil pressure sensor that will cause it.
Vtllcommodore
VT s2 berlina
Yep will be oil pressure sensor these cars are to easy but it should flash the oil light not a svs code car is retarded as ****
Fu Manchu
WA.
Change the oil pressure sensor. $30 part. Takes 10mins to do. Problem sorted.
