Svs warning fix
smitroast
wynnum
vz sv6 commodore
To anyone who has had this warning check the oil light switch which a plug located directly under the oil filter pull the plug out and it's filled with oil you will need to change buy one from your GM dealer will be 82 bucks you will also need a 27 mill deep socket remove old insert and replace with the new this should fix your problem :)
1_johnboy
east gippsland
11` VE Omega
That warning is not just limited to a oil pressure switch failure, I've had it and it was due to a faulty o2 sensor
Sent from my GT-I9505 using Tapatalk 2
richardpalinkas
Blown Alloytec
Gold Coast
Raptor Impulse VZ SV6
I've also had it with my manual fan switch. It's just a non emissions related fault code.
smitroast
wynnum
vz sv6 commodore
Yeah I was just posting because I haven't seen one about this problem
