swaping engines
alan666
bairnsdale
vt vx berlina
hi does anyone know if I would be able to unbolt a v6 supercharger out of a series 1 Stateman and bolt it straight on to a 3.8 v6 engine from a Berina 99 model.
Or would it be better to just pull the whole engine and trans out and do a complete swap that way.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
Complete swap would be the easiest option. The heads on the L67 are different so you would have to swap them over. Also gearbox is different also (different torque converter for a start)
_R_J_K_
Zenki S14
Not to mention the compression ratio is different between the two engines. You'd need to have it tuned if you did a top swap to the regular 3.8.
NeddyBear
Veteran Mountain Biker
Rubyvale, Qld
2004 2.5L Subaru Outback
I thought the Barina is a 4 cylinder job or was there a V6 version?
ephect
Donating Member
VS Acclaim V6
guessing it should read berlina :)
