The dreaded 'MISS'
Ralphski
Ralphski
58
Otaki, New Zealand
MY04 VYII 3.8 Executive - MY11 VEII 3.6 Calais VV6
Aye up.
I have a MY11 VE Series II Calais (LLT 3.6)
VIN 6G1EX5EV9BL543119
Engine LLT
179000kms on clock
It's developed a pesky missfire... Not always noticeable but most noticeable when under load (going up a hill) & sometimes when coming to a stop it'll shudder, almost stall then recover...
So, sparkplugs & coils replaced less than 10,000kms ago, no change.
No error codes
So, what's next team?
greenacc
Searching for the billion
VE Berlina
Did you fit cheap ebay coils?
Check the throttle body, air filter, MAF and all their harness plugs are clean.
J_D 2.0
Ipswich
2009 VE SSV M6 on LPG and 2022 Kawasaki Z650L
Are you sure it’s a misfire? I thought I had a misfire in my SV6 a while ago but it’s actually the transmission on the way out.
If it is a misfire have you checked your air filter and the air intake tract for leaks? Have you cleaned the MAF sensor lately?
Ralphski
Ralphski
58
Otaki, New Zealand
No, no cheap ebay coils. However the miss was there before the coils were replaced. It hasn't gotten worse with them in.
I'll dig into your suggestion, cheers.
Ralphski
Ralphski
58
Otaki, New Zealand
I've never cleaned the MAF during my ownership, no leaks I can hear. Cheers, I'll give the MAF a clean
Also got new O2 sensors on the way
J_D 2.0
Ipswich
Make sure you use contact cleaner or the proper MAF cleaner to spray it down. Anything else will probably damage it.
Immortality
Staff member
Sth Auck, NZ
Are these things direct injection( I can never remember the exact Alloytec model variations)?
Immortality
Staff member
Sth Auck, NZ
You could try an upper cylinder cleaner. The problem with direct injection is nothing cleans the intake valve. with port injection the intake valve always gets washed with the incoming fuel, direct injection doesn't so over time oil can build up on the intake valves. Well known problem with direct injection unfortunately.
