The SC14 Supercharger Thread
stocky
33
Well after replying to threads and PMs posting the same thing over and over again, I figured it time to post up all the information about the sc14 spercharger in one spot. Ill update this thread with more info, but just post any questions you have here about them in regards to fitting, tuning, intercooling, etc.
stocky
33
Hi again, Ok, ill get this thread started...
Q: How much boost can a SC14 push on a 3.8L?
Q: How much boost is standard?
Q: How much are the replacement pullys and what boost do they deliver?
1. depends on the pulley size
2. 3 psi on a v6
3 . $200-300. anywhere up to 12 psi
VN S1
1. If you use 3" intercooling would a 2.5" exhaust be restricting flow?
2. What are the exact (close) measurements of pulleys to psi? (With Belmouth Removed :) )
nicko
Carbon Positive - DO IT!!
sa
75 cruiser ute
A few more i always see;
where can i get the brackets from?
can i make my own?
Do u have the dimensions so i can make my own?
ashzv6
VN v6 s2 Berlina 5spd
hi,
i was just wondering.
wat injectors and tunes are people running?
or are people using stock tunes and injectors on stock boost?
thanks
stocky
33
depends how much boost you run. if youre going 10 psi, the youd want a 3 inch exhaust. pulley size also depends on whether its intercooled or not
can i make my own?
a few people have dimensions for them but i dont know who. you can get crs to make them but they charge too much
hi,
thanks
depends what boost you run
3 psi - 1 bar tune with creamtop injectors 21lb/hr i think
anything higher than 6 psi - l67 injectors (36lb/hr) and a 2 bar map sensor tune
azkwazere
Ahhh Yes, Ahhh Yes....
33
.....SE Burbs
VP 5-SPD / 24-SPD Racer Hybrid
Can i have your SC14?
and if not... how about your engine?
aZk.
stocky
33
VN S1
Hehe i was meaning more on sizes like:
75mm Pulley equates to 10psi..... type thing (with bellmouth removed)
