ThIn oil
Status
Not open for further replies.
bruiserbrad
VC 202 base model
my car started blowing smoke bad the other day so I checked the oil and it was really thin almost like the consistancy of water. I changed the oil today and as soon as I started the engine up and when IChecked the oil it had already turned to the water consistancy.
Has this happened to anyone? Does anyone know what the hells going on??
bruiserbrad
VC 202 base model
I was thinking it could be my fuel pump leaking into my oil? Could this be a possibility? How could I fix it or check it?? Any help would be much appreciated
machone
VHSLE/VXSS/VXEXEC
you cold have a crack in your fuel pump in the diaphragm....undo the sump plug or check the dipstick if it smells of petrol then thats what id say it is
ari666
250,000 hits
WTF am i reading???
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
So should i put my face right up against the sump when i undo the sump plug to check for a smell or wait?
Darcon666
Evil is always around you
At home
www.gfy.com
Your Mother
Ummmm.... unless I am mistaken(...and I am NOT a mechanic) the fuel & oil systems in any modern internal combustion engine are completely independent of each other.
So, WTF????
ari666
250,000 hits
well, the mechanical pump attaches to the side of the block and is oiled, so theor-echnically it is possible, but the chances of the pump diaphram leaking, then fuel miraculously running through the pump assembly, down into the pump crank, then BACK UP into the engine, are really really really reallly low.
if i had a clue what the OP was on about i would post some kind of better answer, but for now i am just left speechless.
VKCOMMO
Carpark Mechanic.....
Springwood, NSW
Is anyone else thinking apart from fuel in the oil... such as maybe the watery consistency is... well.... water?? Head gasket cracked?
Status
