Yeah it starts at 28, i give it a tap and it goes down to 13%. ive just seen its max is 38%. faulty sensor most likely or would there be an error code if throttle was actually f*ckedPretty sure it should be 13% once the idle comes down after start up.
Unless there's an actual problem that you've identified and effects how the car drives, don't base your problems on what you think about the engineering numbers. There are a number of parameters that govern idle speed and how much throttle is needed to maintain that idle.Yeah it starts at 28, i give it a tap and it goes down to 13%. ive just seen its max is 38%. faulty sensor most likely or would there be an error code if throttle was actually f*cked
