Torque setting to tighten the brake caliper bolt when changing front brake pads on VE.
BR33ZE
42
SV6 MY12.5 series 2 sports wagon
Gday folks, Does anyone know the torque setting or point me in right direction for the torque setting for the caliper bolt (12mm i think it is??) when tightening back up after changing the front pads on a VE commodore?
cheers,
shane_3800
35
places
vr commo
Ugga dugga or FT.
vr304
Auckland, New Zealand
2007 ssv manual
I’ve never bothered torquing the caliper bolts and never had any issues just do them up tight and call it good, put a little bit of blue loctite on the threads if you’re paranoid
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
cheers,
been a while since I did a set... but my recollection is you DON"T remove the calipers to change pads on VE
Fu Manchu
WA.
I don’t think anyone in history has replaced the bolts or torqued them. FT for the win.
Fu Manchu
WA.
Good point. Undo the guide pin and swing it back. Out with the old pads, in with the new and tighten up the bolt again.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Maybe he changed the rotors as well.
stick3
newcastle nsw
vz sedan vs ute gsx1400
i remove the bolts to clean and lube the slide pins and i think the torque specs about 30-35nm but i do them up as tight as possible and recheck about 1000km
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
The specs are in the manual and the manual specifies that those bolts are discarded and new bolts used when reinstalling)…
