Deutscher
Hi,
I recently brought a 1990 Toyota MR2 SW20 N/A for $6k, 173,000kms on the clock, targa, full alpine stereo. When I brought it had a minor problem, possibly stem seals but worst case recon head. Thought for $6k... normally MR2's sell for $8k+ the money should cover the recon head and I'll be out on top.
Unfortunately, I found out that it loses oil somehow somewhere. It's not dripping to the floor but I can't see blue smoke to see if it's burning and the coolant colour seems normal. The thing is I'm losing 1L of oil per week! So I've taken it to a reconditioning workshop and got a CO2 test done and came back as a blown head, and got a Compression Test done and came out with 150, 150, 150, 145 which is in the specs, so I shouldn't worn piston rings etc.
Now I've taken my car to RAC and they can tell it's losing a lot of oil but they don't know where.
They've quoted me $6600 for full rebuild or $3300 for head rebuild. Guy said he doesn't know if the head will fix the oil aswell or if it's a bottom end problem and would need a full rebuild. They can't tell until they open up the engine.
The other course I'm thinking is putting in a replacement engine, I found this, asking $1500.
Apparently the head gasket leak isn't major, just gets hot quickly. I was thinking taking the Mild Reconditioned head of the spare motor and putting it on the other motor. I'll have a test drive of the car and might get RAC to have a look, he said I could do a compression test on it etc. It just sounds a little weird to me. But it won't hurt to have a look. What you guys think?
"3SGTE GEN2 complete driveline and ECU, includes complete motor, gearbox, turbo, intercooler inc piping, ECU etc. Gearbox has been rebuilt. Turbo has been rebuilt and high flowed and steel exhaust wheel installed.
The whole package has aprox 85,000 Kms on it. Car has been maintained well by Tony Flood Mechanical.
This package can currently be test driven in the car but will be removed soon for a GEN 3 upgrade. The motor has a suspected small head gasket leak.
Also included is a spare GEN2 3SGTE motor (head and block only). Head has mild reconditioning done, block has worn rings."
