Transmission
jujibelly
ERROR_PATH_NOT_FOUND
Melb
Vr Commodore
See I already know the common symptoms of a trans fluid leaking internally in a radiator but the problem is that there is no coolant on the transmission dipstick (the fluid is still at optimum level, clean and red still) but therein lies the problem.
nathanVY
such boost
Geelong, VIC
2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
Not sure how coolant can be leaking out the transmission pan gasket then..
D3V14NT
Likes Shiny Things
Geelong, Vic
93 VP BT1 V6
Can always drop the pan to confirm if there is coolant in there or not. But you would think that it would show on the dipstick if it's leaking out from the pan gasket. Maybe try removing the trans lines from the cooler and topping up with water to see if it flows out from the trans line fittings.
It's possible that the heater core is leaking with the majority of coolant running out the drain pipe with the remainder drying off the heater quickly due to the heat. When you lost all the coolant was the heater tap open at all? Shouldn't have any flow into the heater core if the tap is closed.
Darren_L
Toowoomba, Qld
VH SS
There is no gasket between engine and transmisssion, it is leaking from the transmission sump gasket. That was my inital check after seeing no coolant around engine area, but not a single drop of moisture around heater core area.
just to clarify by 'coolant on the floor' do you mean there is there coolant on the floor inside the car ?
if there is, then the only thing it can be is the heater core. You won't necessarily find moisture directly under the heater case because the case has a sump which usually drains out the drain tube or if it's bad enough it will overflow out the floor vents onto the floor. There is no other way coolant will get on your floor unless you literally spill a container of coolant on the floor....
nathanVY
such boost
Geelong, VIC
I'm thinking it's probably leaking somewhere else and dripping near the pan gasket making it look like it's leaking. The only way for coolant to leak out the transmission pan is for it to be mixed with transmission fluid (there is literally no other way). Possibly heater tap or coolant hose at the rear of the engine has split/cracked and is leaking and dripping down the back. As suggested possibly the heater core (if it is inside the car then it's definitely the heater core)
jujibelly
Melb
Vr Commodore
Nah no coolant at all inside cabin.
Yeah it's got me stumped, I am going to drop the trans sump sometime during the weekend and see wtf is going on. Will let you guys know if I find anything interesting haha.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
theres no water in the transmission at all the closest point of water is the rear of the engine ide say its tracking along the bellhousing and onto the box or leaking out of a heater hose down the firewall onto the box.trans fluid would be pink milky milkshake all ready if it was inside the tranny pan
erin.oldman
45
Australia
1992 VP vacationer
if there's coolant on the floor of the car, then your heater core is leaking
that would also account for the coolant dripping from your transmission. The heater/air con box drain tube exits from the trans tunnel above the transmission. So it's probably dripping on the trans and running down the side.
heater core replacement is a dash out job. Short term solution is to disconnect your heater hoses until you get it fixed
Hi Darren, I’m a new (girl) 1992 VP owner lurking here for awhile having just put a new stereo head unit in and replaced the fan speed resistor. Now it’s time to fix the heater core. Previous owner capped the hoses. Can you please point me to a step-by-step? Pretty familiar with dash removal and cracking small bits of plastic already.
PS Love your work and hope you’re still around to help.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
And here am I replying to a 2011 post.
Shoulda gone to Specsavers.
Come to think of it I DID go to Specsavers.:(
