As u put it, an existing hole contains nothing, so u put a hole in a barrel, which the hole weighs nothing because it contains nothing. And it makes the barrel lighter.. It's not rocket science, it's a hole!
pour from the 5L bottle into the 3l bottle till its full, then pour the rest of the 5L into the other container.
Repeat the process again.
You should go for a job at ACA. That's not what I said at all. I said a hole is an absence of something, as it is. A hole in the Earth is a space void of earth, no substance. A hole in a wall is not absent of all other possibilities. It means there is no wall there, just like a hole in the Earth would mean there is no visible Earthly matter there. But not nothing.
You have to measure exactly 4 liters of water, but you only have a 3-liter bottle and a 5-liter bottle. How do you do it?
What's the question? I'm confused with all old responses!!
Patriot.
it makes total sense. you put something in the barrel. You can "Put" a hole in something.
