180sc
- Dec 14, 2006
- 596
- 2
- 18
- Location
- deception bay
- VS Calais & vh sl
I honestly dont know why your finding it so hard i really think your over complicating the whole thing.
With my th700 behind the 350 chev in the vb i used a v6 kickdown cable (its shorter then the v8 cable) with the holley bracket Holley Performance Products GM AOD Kickdown Cable Bracket#20-95 watch the video on that link at about 1:30 thats how its done. I know your using a quady but surely you have enough skill to adapt this sort of system to the quady. and as a side note those holley brackets don't work even on the right carb i had to modify mine quiet a bit to get it to work and ended up ditching the one off the carbs throttle linkage and making my own because the pull ratio was out and i was getting bad shifting until i set the cable location as per my diagrams earlier. also if you dont want to have the throttle cable on the same bracket just cut it off and use the standard one if it doesn't interfere.
