PUSHIN
- Jun 20, 2009
- 472
- 0
- 16
- Age
- 31
- Location
- latrobe valley
- Website
- www.myspace.com
- 3.8L S1 VN & Sr20det 180sx
alrighty so my brother has a 93 verada.. a week and a half ago, I had to go jump start his car.. two or three times, no biggie, buy a new battery, sweet. NO. got another battery yesterday, put it in, went to turn over the car and it sounded as bad as the original battery did when trying to start, then barely started the car, ran it for a bit, killed it, tried to start it again and still barely kicked over, he went down the street, again, barely started, went to work again, barely started..
So today i went up, cleaned all the crap off the terminals and such, did what i could to make sure it all looked alright, still barely started. so I got the idea to hook it up to some jumper leads from my car (wondering about the starter mainly.. and i know my whole charging system is A1, plus the Optima yellowtop, i KNEW there couldn't be a lack in charge.) So anyway, jumper leads are on, my vns running, go to start it, hardly starts. killed it, waited a few minutes, revved my car a bit to make sure we could get some good current going, tried again and barely started, turned it off again after a minute or two, waited and tried again and it didn't start at all, after a few more tries it eventually started (just), which was when we moved it back into the driveway, and left it.
any time it tries to start, it sounds like the battery is on its last legs, and has just barely enough current to turn the starter, but due to the fact this still happened with the jumper leads from my car, and i KNOW my charging system is more then sufficient to start the verada, i'm now under the assumption that the starter is stuffed, the plan is to yank it out and replace it, however i just thought i'd post my progress and see if anyone else could confirm my suspicions at all? Just money doesn't particularly grow on tree's, things have been tight to say the least, and being that the car has to go in for a roady at some point (and most likely getting sold) we dont have all the money in the world to be throwing at the damn thing, so i figure i should be sure (or atleast get a second opinion) before i go telling him to buy a new starter..
another plan was to use a tester, just I don't own one personally, and my trusty electrician mate with the hella expensive tester is unfortunately in hospital at this current time so that stuffed that one, unless i can borrow one elsewhere. (if i can, i plan to test the power cable for the starter, which if the cable is fine i figure will confirm my suspicion, if there's definitely enough charge, and a good cable to the starter, yet still weak starting, i dont see many other options..)
Any suggestions or anything would be much appreciated! even if anyone has ideas of anything else to test so i can rule other items out would be great! Thanks heaps either way everybody!
