Trouble Starting
Dane Maff
39
Ve Sv6 2008
Hi guys I’m hoping someone can help me out with my ve sv6..
It starts pretty good when cold but once it’s warm I need to pump the gas to start it and once it does start it doesn’t give that initial higher rev it just goes straight to the lower rev which seems a bit too low.. sits at around 600 rpm and sounds like it’s slightly labouring.. it definitely labour’s while the ac is going and to restart it after using the ac it’s even more throttle pumping required..
a couple years ago I replaced the throttle body because the old one **** itself and I think the problem started recently after that.. if not immediately..
any help or advice would be much appreciated
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
fuel injected car no need to pump accel, does nothing, need to scan it first
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
EFİ engines doesn't need pumping, I think your purge solenoid and / or CAS is buggered ..
It also pays to checking your alt. and batt.
