Truetrac / Wavetrac vs Stock LSD
White Swan
NSW
VFII SS
They're all rip-offs of Quaifes anyway, aren't they?
Quaife has long been considered the international benchmark for good mass produced performance diffs.
The stock LSD in the SS Commodores is very very ordinary at best and for a long time has had a bad reputation for not being able to equalise the output to both wheels.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
What's the difference between the two, what do Harrop do?
Harrop machines the case from billet steel, and uses 8 pinions.
Eaton uses a cast case and 6 pinions.
Forg
Regal Peackock VF SS-V Redline Wagoon
Ah, so this is a complete replacement, the whole pumpkin or even disc-to-disc?
I only installed Eaton parts to mine, because I was only replacing the gearset itself - the case & bearings are stock (not a Commodore) ... kinda wished I hadn't had that part delivered to work & then had to carry home on the train ... I guess the Harrop for the SSVR would be worse though. :)
lmoengnr
Donating Member
Sunbury Vic.
Just the differential it self.
Forg
OK, now I'm even more officially confused than before! :)
Do Harrop call it a Harrop Eaton Tru Trac because the design itself is license/owned by Eaton, but Harrop makes a sturdier version of it?
lmoengnr
Donating Member
Sunbury Vic.
Yes!
arthurk
SSV Redline VFII / SSV Motorsport KOM0993
Harrop has a version based off the original Eaton truetrac
arthurk
I have looked at Quaife as well but I could not find a unit for the VF, more to the point couldnt find a GM/Chev/Holden unit.
SnowDoggyDogg
2ltr? = Only milk & juice
Goldie
Gen F GTS
In my mind if you are going to fork out for aftermarket parts and the labour to install it makes sense to buy things that are not going to be the bottleneck down the road.
So an eaton trutrac at 500rwhp could become the weak link in your driveline pretty quickly on a 6l or 6.2l LS engine.
This is why the Harrop, albeit dearer, doesn't leave you having to upgrade again if/when you want more power.
arthurk
My car is already at 422rwkw so if I do go truetrac it will be the Harrop version.
