VT-565
that is a sequential setup you are talking about there. i once saw in a magazine a rail that was running an RB30 with the same setup. the only problem i can see with them is sufficient intercooling. for a V8 though, if you do your maths right, you should be able to have two evenly sized turbo's, without having to worry about excessive lag. then on the other side of the coin, you could look at a centrifugal supercharger setup, there have been a few big prochargers installed onto cars here in oz recently and they are capable of supporting big power. thats the way i would go.Majesticknights said:also throughout the week i spotted a diffrent type of twin turbo. this was in a mazda sedan drag car, it has a small turbo feeding into a massive turbo like a truck one it was that big and this car can almost wheelstand the whole drag strip.
i was looking at this config but i will go the most cost effective in terms of power for $ has anyone seen this turbz setup the little one runs from idle to bout 5800rpm and then the big one takes charge
what do u think of this and would it be the better option?
