Not_An_Abba_Fan
Exhaust Guru
- Aug 18, 2006
- 14,639
- 1,364
- 113
- Location
- Bunbury, WA
- Strange Rover
Hello again Not-An-Abba-Fan. Could the noise of a dry centre bearing possibly be mistaken for a diff problem noise by two mechanics?
I only ask this because I've just got back from another mechanic's today. He's been recommended by a few friends of mine and this is what happened.
Took it for a quick drive and did all the usual tests, swerving side to side, accelerating, cruising, decelerating etc.
While all this is happening he's telling me it's hard to diagnose noises like this. “Don’t know…could be any number of things”. But then at the end of the test coming back he says “yeah… I think it’s the diff”… but he didn’t sound really sure.
His advice was to keep driving it. If it gets worse it will be easier to pick where the noise is coming from. Also to add a $15 tube of Nulon G70 to the diff oil and see if it makes a difference.
I’m off to do that right now.
And he said this after you told him it could be the diff?
A test to do, but I will warn that it can be dangerous if not done correctly, is to lift the rear wheels off the ground and support the car with axle stands, chock both front wheels, have someone in the car and start it up and put it in first. Let the wheels spin and using a screw driver as a stethoscope, put it against the bracket that holds the centre bearing and see if it is noisy. It will be very pronounced through the screw driver. You put the metal tip on the bracket, and then put your ear on the end of the handle.
