You need to look at it holistically
Your converter stall should be based of your cam, diff gears, engine power, and importantly what you use your car for, street? drags? 90% street 10% drags, this bit matters alot
If you mess this up you will have issues and the car will not perform optimally for what you mainly use the car for
Then, once you know what stall you require for your cam and diff gears, get the transmission tuned
It isn't as simple as just bolting random stuff in, but, if you do your research and speak to a "good" automatic transmission shop that does alot of performance stuff you will be fine
And then, if you add boost later on, especially PD, you may need to revisit the cam and stall
#science
