Upgrading VR V6 brakes to V8 or possible VT conversion
crazybiker
Sydney NSW
VR Commodore V6
Hi there.
I currently have a VR V6 with ABS, and would like to upgrade the brakes to V8, at the least.
Now, I seem to have trouble sourcing a VR V8 brake booster, and master cylinder WITH ABS to put in. So it makes me wonder, was there a double diaphram booster and 1" master cylinder made to suit ABS?
Now because I'd like to get my brakes feeling better, if a V8 setup with ABS is out of the question, the next choice really for me, is to put a VT system in it. That brings a few questions.
1. What will I need?
2. Would there be a difference between a VT V6 and V8 setup?
3. Will a VT setup work with my VR ABS?
4. Will it all fit under the 15" rims I've currently got on the car?
5. With the upgrade, is it only the booster, master cylinder, and front calipers that get changed? Do the front discs get changed too?
6. Do the rear brakes get touched at all?
Thanks, Cameron
ephect
Donating Member
VS Acclaim V6
There is a massive amount of thread on upgrading brakes.
most v8 brakes are the same as v6 brakes, its only the big brake kit that's different in the different vr vs range. If U upgrade to VE brakes U don't have to change boosters or masters.
TI3VOM
Here there and everywhere.
VT Commodore
most v8 brakes are the same as v6 brakes, its only the big brake kit that's different in the different R vs range. If U upgrade to be brakes U don't have to change boosters or masters.
If you upgrade to VE brakes you don't have to change boosters or masters.
Fixed it for you.
ephect
Donating Member
VS Acclaim V6
Auto correct doesnt like ve's lol
Thanks mate for picking it up
FstStig
Diagnostician
34
Central Coast, NSW
2010 VE SV6
Agreed with above, don't waste your time going a V8 upgraded the only real difference is the brake booster and master cylinder, everything else is the same. VT upgrade requires a bit of stuffing around and making up a bracket for the brake booster. VE upgrade is the way to go, not only will your braking feel better but there is a lot less stuffing around to be done.
crazybiker
Sydney NSW
VR Commodore V6
I wanted a VE brake upgrade, but, I can't fit them under my current 15" rims. Thats why I'm looking at other options
TI3VOM
VT Commodore
It may work out that same cost if you search for some second hand rims, that will fit the VE brake upgrade.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
It's just a 6. Get some decent brake pads and some slotted rotors. Done.
crazybiker
Sydney NSW
VR Commodore V6
Pads and rotors aren't my main concern.
It's more M/C and Booster.
Which makes me ask, is there a 1" master cylinder to suit an ABS?
FstStig
Diagnostician
34
Central Coast, NSW
2010 VE SV6
Search for a BT1, calais, berlina, statesman or caprice that had a V8 in it and you will be set to go.
