USB for Music
Chalks1971
Tathra, NSW
2019 CALAIS ZB V Tourer
Morning all. This is doing my head in.
Ive had my car for a couple of years & always had a SanDisk 256GB Ultra Fit USB inserted into one of the USB plugs in the centre console. Recently my system stopped reading the USB, so I replaced it. Its happened before in this car, & previously in the VF. For clarity, I have 115GB of music, so the thumbdrive isnt full. I normally use mediamonkey to transfer the music & playlists to the thumbdrive, but Ive also tried just saving my files using windows explorer.
I bought a new USB (Ultra Fit again) but my system still isnt reading the USB. Normally it recognises the new USB & takes a while to index the content.
Ive checked the usb plugs are working by attaching my phone to each of them.
Any suggestions?
PS I travel alot in areas with no mobile reception, so just using Spotify isnt an option
stooge
wa
Turbo Alpaca
make sure the drive is fat32 formatted or exfat, fat32 is the most compatible across many systems.
if it still does not work find a device to test the data lines of the usb, maybe a small older usb stick with 1 song on it.
another way to test is to plug your phone in and see if carplay or android auto work, if they do work then the usb port/hardware is fine and it will be something with the usb drive you are using.
kwhelan
59
New Zealand
ZB VXR
Did you solve this?
I just bought a 64 ultra fit and have the same issue, tried fat32 and ntfs which both work on other sticks
tried external harddrives of 500 gig and that worked so it doesn't appear to be size
have proved the ports both working,
tried a usb xtn cable in case it was something weird with the ultrafit not inserting correctly
it appears the car just doesn't like ultrafit drives at all
doing my head in!
