V6 conversion
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Engine loom should be pretty simple to wire up, power to the ECU, power to the injectors, earths, and the main feed wire to the ignition. It will run without the gauges. Change the temp sender to one that matches the resistance of your gauge and that will work.
Holdenstylez
46
New zealand
Vl, vy
Yeah had a feeling thts wot it wud b bt am tryn to find out if any1 knws wot wires frm the engine loom i need to connect to the vl body loom. Thanx for the surgestion
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Body loom and engine loom are separate. You shouldn't need to connect the 2 at all.
losh1971
North Tas
VE Series I SS Ute
Try writing in plain English not Millennial translation of English.
H
harrop.senator
Guest
You obviously don't have a lot of friends from new Zealand. I'm surprised how legible immortal is . Always did my head in with the boys from the long white cloud .
I haven't played with anything vl related engine swap wise.
But when I put twin cams in r31's it was always :
Wire up a fuel relay that's switchable by the ecu. I think it's the earth that's switched and it always has constant 12v.
Main power to the ecu.
Accessories and ignition to the ecu.
Tacho signal from dash to the ecu .
Speedo signal from dash to the ecu.
Delcowizzid is the man I'd be hollering at.
Immortality
Staff member
Sth Auck, NZ
I'll take that as a complement?
Immortality
Staff member
Sth Auck, NZ
Yeah, nah, yeah. Sweet as bro ;)
Immortality
Staff member
Sth Auck, NZ
Or maybe I just finished high school?
