s_ikari2015
Fun IS easier with an 8
- Nov 16, 2007
- 697
- 30
- 28
- Location
- Australia
- '02 Monaro V2 CV8, '90 Toyota Sera
Greetings! So I've acquired a 1979 VB Commodore SL/E as a project. My goal is to repair/replace everything broken/missing and then sell it to someone who will love it for years. This isn't the first car I've worked on and won't be the last, but is the first one I've set a timeframe and budget in order to "flip" a profit.
So it has the 253 4.2L V8 with the Trimatic 3 speed auto, all into a Salisbury GU7 2.78:1 diff.
Original Nocturne Blue in colour, even though the clear has been resprayed (cheaply) and has glitter in it... yep, I know, but it's barely noticable.
Interior is in good condition, mostly, and the whole car falls into the "Survivor" category. Around 98% complete when I picked it up. I've been hunting around for all the missing and broken parts, just really need the Left headlight wiper arm and blade.
A lot of the electrics don't work, so I'll be pretty much removing the entire interior to check all the cables and components. I hope there isn't much to replace.
In summary the following was wrong with it when I bought it:
So yeah... some pictures. I'll add more as I progress on the semi-restoration.
I've got a video uploading at the moment, will post it when it's done.
- Front electric windows didn't work - switch cleaned fixing one, but other has busted regulator
- Speedo didn't work - replaced driven gear, started working but was way out and wobbled, so needs new drive gear and different driven gear
- Fan doesn't work - don't know why, might be switch, might be relay, might be wiring
- Heater core is bypassed - guessing it's cactus, thus why the heater switch is jammed shut perhaps
- Aircon doesn't work - won't switch on so can't check compressor clutch, may be linked to fan not engaging/relays again
- Clock not working - light works but mechanism cactus, replacement sourced
- Electric aerial doesn't work - switch makes it go "meeeeep" but won't budge, replacement sourced
- Transmission slips out of gear - filter kit didn't fix it, needs a professional... also to install the speedo drive gear
- Exhaust mounts missing/broken - replacements sourced
- Headlight upper chrome mouldings missing, both sides - got em
- Left headlight lower chrome moulding missing - got it
- Several window bailey channels perished - got the new stuff
- Window weatherstrips/belts perished - got them too
- Centre vent broken, bashed in - not happy about this one, but got an excellent replacement part
- Front left wheel bearing noisy - font end kit in the post
- Sunvisor clips missing - guess what... yep, got them too
- Carpet missing in driver's footwell - all new carpet on the way, will use the old stuff to hide the speaker holes cut into the kick panels
- Central locking doesn't work - aftermarket kit ordered to replace it, not worth trying to figure out why the factory stuff doesn't work. Might try it when I remove it, sell anything that still works
- Front passenger interior handle chrome surround missing - got it
- Left front bumper over rider missing - on the way
- Interior light lense - you know I've got that
- Drivers door lock missing - new barrel set on the way. Going to keep the boot and glovebox the same, have a "valet" key which only does the doors and ignition.
- Flasher unit was dying - replaced that
- Under bonnet light - amazing what you can find on the interwebs
- Clear coat pealing in places, like the roof - got the paint, gonna tackle that soon
