I recon change male female plugWell that's not very good then is it
What ya recon change plug or re wire it
That's what I did when I converted the VK from 6 to 8 and it works fineno....
Yeah, basically all you need is green for temp sensor, blue for oil pressure, brown for charge light from alternator and make sure you bridge the yellow & pink wires from ignition to make sure you always have 12v for high energy ignition coil.Is it same colour wiring if I change plug for the most of it ??
Very easyThanks mate to easy by the sounds of it
