VC seatbelt lower area
Goon
Scientific Tuning
BrisVegas. QLD
VY CUSTOM.
Hey all
Does anybody know how to remove those pin things that hold the case at the bottom of the seatbelt area, i need to put wires under it :p
Thanks
SL/ENUT
The SL/E Fanatic!
Burnie, Tasmania
VB SL/E 5L
!Please do this slowly and be patient, very brittle plastic!
Ahhhh i know what you mean. You need to grab a small flat head screw driver and there is a slot cut in the pins that hold the seat belt cover on. Prise the pins slowly cause these are very brittle. Once all 4 pins are out so far, nearly all the way the cover can be taken off.
V-ahhh
SA
VN/VT
yeh what he said^^^^^
Outlaw Torn
Opononi, NZ
91 FORD EA Falcon (So sue me)
from memory u might need to loosen up the trimmings on the sill to replace it properly, but this is only from memory.
