Liam_D_07
- Dec 5, 2013
- 3
- 0
- 0
- Location
- Berwick
- VE series 2 SV6 Sportswagon
Hey guys some some quick questions, I was going to replace the stock speakers and run the new ones off an amp. So the amp I got given off a mate it has some hi level inputs but also has RCA inputs?
1.Do you think I should install a line out Converter and use the RCAS or just use the high level input as it saves installing the LOC?
2. If I use the high level inputs the amp doesn't say which wires are to go where into the amp? Does this matter? I thought it would be like RCAS with a designated spot?
3. And does anybody know the output voltage of the headunit it's a sv6 series 2? The amp says it takes anywhere from 200mv to 4v? I'm assuming/hoping it falls between that range?
4. Is this a project you can do at home or is it better to pay someone to do it and how much would a good installer cost? I haven't really done much work on car wiring before but do know my way around some electronic stuff? To me the worst stuff looks like taking off plastic without snapping the clips!!
Cheers for any responses
