VE Commodore v6 coolant issues
Clayton Williams
Sunnybank
VT 2000 3.8 Sdn Executive II Olympic Edition
Hi all, I have a VE 2009 V6 Ute. I am chasing a coolant leak which appeared in the left top corner of the water pump and some coolant was also in a hole just above that.
It is a treaded hole in the block, i am wondering if something goes in it. I suspected water pump so replaced and a few days later it appeared again. tried to insert pic
but won't work. cheers
Fu Manchu
WA.
Chances are it’s the coolant inlet manifold gasket. The coolant inlet is the metal part that the filler cap is on. It’s a cheap fix. It might be running down the front from there.
A photo would be handy.
losh1971
North Tas
VE Series I SS Ute
Fu Manchu
WA.
I take the photo, then turn the screen to show the image on the smallest size (either horizontal or vertical) and screen shot it, then crop, then upload. Done in seconds.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
If using Windows, Microsoft has a pic resizing app that shows when you right click on the context menu.
You can resize to small, medium or large, as well as custom sizes.
losh1971
North Tas
VE Series I SS Ute
I email them to myself on my phone and select small.
retroject
47
Adelaide, Australia
VE Calais V LY7
I have a similar issue after having the water pump 'professionally' replaced. I also see a similar threaded hole. Is there a bolt missing or is this because the water pump is a different model?
greenacc
Searching for the billion
VE Berlina
It will be the river o rings between the filler neck and the block. Just above the water pump. Fairly easy job to replace and only cost about $25
greenacc
VE Berlina
Rubber O-rings. You buy them in a 2 pack, 1 is round and the other is kinda square. F#@King auto correct is bad today!
Fu Manchu
WA.
Dog autocollect lake sponge glide duck Ken won’t write the chicken scabs should.
