Ve commodore
Hbear
60
Dumbleyung
VE Commodore
I changed the automatic transmission in a ve commodore the torque converter had burnt fluid so I emptied it. I put the torque converter on the transmission put the transmission back in now it will not even start. I checked all the wires and they are all connected and I don't know what the problem is
losh1971
North Tas
VE Series I SS Ute
Try bridging the starter motor relay. that will help narrow it down.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
The shifter mechanism rigged up correctly?
krusing
Melbourne, Bayside
Did you physically change the whole Transmission?
Or just the fluid ?
If you changed the complete Transmission,
and didn't use your exist TCU,
You will possibly need to link the ECM & TCU.
Ccoastcalais
Central coast
Vf2 redline, Ve ssv
Make sure the transmission is in park or neutral. The inhibitor switch will prevent it from starting if it’s still in gear. You may have to adjust the selector rod.
