WreckWren
Polylast, the 1590AK with the bigger VF bearings. Very happy with them, nice and soft and feel great. By "no improvement" I meant in regards to the door noise, the car drives much better with these bushings and bearings than it did with the OEM ones.Which SuperPro strut tops were fitted?
Polylast or urethane?
That's a real drag. The manual mentions a torque spec for the pin retention bolt, so I was hoping it could be changed individually. To replace the whole hinge I'll have to do some paint & all that.On VE the whole hinge needs to be replaced. That will require some planning, some nifty spray can skills. Some guidance.
There is the factory manual you can download for the instructions for the job there once the side bar is enabled for navigation of the document.
I gave the door a wiggle up and down with it mostly closed and sure enough the panel gap at the top of the door changes size indicating the top hinge is most likely buggered. Reasonable assumption?
Do you know if GM still sells new hinges for these?
