VE front speed sensors
Sam6oych!p
VE SV6 Ute series 1
Hey there, I've read conflicting threads regarding front wheel sensors.. can you replace just the sensors similar to the back? Are they the same style? Trying to avoid replacing whole hub.. thanks!
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
They're part of the bearing/hub assembly. Stub axle doesn't need changing
Sam6oych!p
VE SV6 Ute series 1
Bugger.. I'm trying to avoid that, abs module or ecu too.. the actual code is c0045.. I've changed everything at the rear though.. someone told me to try the front but code says rear new rear sensors, new rear loom, cleaned bearings.. same code comes back..o2 sensors done
Sam6oych!p
VE SV6 Ute series 1
losh1971
North Tas
VE Series I SS Ute
Check the rear harnesses. This is another common problem.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
