VE headlight - Is it haze or something else? Can't remove markings.
dbob-001
51
VE Series 2 SV6 Commodore
Tried cleaning my headlight on my VE Series 2 SV6 with a Turtle Wax Headlight Restorer Kit to remove some haze and minor yellowing.
However not sure if its haze or something else as there still appears to be a thin layer across the bottom half of the headlight.
I tried a few more passes using the scrubbing pads from the Turtle Wax Headlight Restorer Kit but it doesn't seem to remove the markings.
Not sure now whether the product is not working properly or there is some other kind of damage besides haze?
Anyone else seen similar markings?
Any ideas or suggestions to remove?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
It looks like part of the original UV coating is still there.
You might need to be a bit more 'aggressive' with the headlight polishing.
Skylarking
123
Downunder
Commodore Motorsport Edition
For years headlight lenses have been made from polycarbonate and have had a UV resistant two pack clear coat applied by the headlight manufacturer when they were first made. The problem is that the clear coat will eventually degrade and start to come off leaving part of the lens without UV coating and part of it with some UV coating. Such makes it hard to correct the problem well unless aggressive action is taken to sand the lens so no clear coat remains and then apply new UV resistant two pack clear coat to finish it off correctly.
I've posted a few video showing on various threads how this aggressive sanding is done and also linked to where one can buy the two pack clear coat. Search is your friend ;)
Basically those headlight restore kits that one pics up from auto stores are cheap and will never do a good job. It's much like buying rattle cans to do a shut door respray... Everyone's outcome will be different ranging from crappy to not so crappy with only few doing a 1/2 decent job.
Buying the UV headlight clear coat is pricy (becuse they dont have really small containers) as seem below
The following mob seems to be provide it as a service in Gold Coast and Sunshine Coast but may have associates that do the same in Melbourne
PS: the UV clear coat also provides abrasion protection to the lens which is something that bare polycarbonate can't do. Neither can those Acrylic clear coat do it well. Basically a two pack UV resistant clear coat which is the closest to what the manufacturers use is the best option longer term. Really, it ain't too expensive to have done considering what kits cost and the time you waste faffing about with those cheap kits.
Fu Manchu
WA.
You won’t remove the coating by polishing. It needs to be sanded back.
Progressively working toward 1000, 2000.
Then 2K clear or I use duplicolor headlight coating.
I’ve done two or three threads on it I think
losh1971
North Tas
VE Series I SS Ute
If the clear coat is peeling try a Karcher or maybe a powerful carwash hose. Once 2k starts to peel you can sometimes remove pretty much the lot with a few goes with a pressure washer. 2k delaminates once it starts going as it just lays over the top.
Fu Manchu
WA.
It’s not 2K on the lens. It’s the UV protective coating. Has to be sanded off.
losh1971
North Tas
VE Series I SS Ute
Ok, fair enough. Mine is coming off on one light on it's own with what I think might just be the hose nozzle.
Fu Manchu
WA.
It might have already been painted with 2k clear.
The one posted has the factory coating degrading. It has to be sanded. Any other method is just going to result in an equally shitty looking light.
Just needs some care and work and will be like new.
  • Like
Reactions: Lex
losh1971
North Tas
VE Series I SS Ute
I replaced the lights with a brand new pair. One had a little nick in it when I bought it. I thought nothing off it at the time and now I have lost over 40% of the coating. Must be cheap coating? Only one light is affected.
losh1971
North Tas
VE Series I SS Ute
I thought maybe the bulk would come off, with a decent blast since I thought I saw it mentioned it's a 2k coating?
Best way is your way Fu, take the lights out and do them really well.
