Gday, just wondering if anyone has used Ve seats in Vs ute. Can use use the VE rails or swap over Vs rails? Any help appeciated.
I have just checked the width of the seats in my VE and VS. They are both the same so you will be ok there.
I haven't done that conversion but I have put Recaros in my VH. The principle will be just the same as the chances of them being a bolt on are zero. I used a piece of flat iron, I think it was 50mmx5mm across to pick up the existing holes. I then had a 50mmx 20mm box section steel running length ways and welded to the flat iron to pick up the runners on the Recaros.
Unlike you I don't have electric height adjustment so that will be something you will have to sort out.
Make sure when you have done the job that you get a modification certificate. I can't stress enough how important it is to get one. As it is a ute you will have to fix the certificate to the engine bay. Silicon is fine.
