Everything works except the camera when selecting reverse.
The Aerpro facia has a Reverse wire (pink), I dont see any power from this wire when I select reverse. Do I need to have the cars reverse camera feature enabled to see a voltage from the facia reverse wire ?
I was thinking I would plug the facia reverse to the head unit reverse and wire the camera +ve to same.
Before I remove all all the tailgate trims again and run a hard wiring back to a reverse light though I'd ask what others have done.
Facia does have some reverse visibilty, because if I select reverse, the reverse sensors display on the new facia (when park brake is off).
If I wire camera to constant 12V, it works when I go into setup or if I put 12v directly on the reverse wire to the headunit .
If the Calais wagon had the factory camera as an option, would the light green reverse wire be accessible in the harness up the front of the car ?
