Kiwive
Hey guys.. in the process of Changing my caster arms over on my ve ss.. took my car in to the Mechanic and he said my caster arm bushes are gone.. have decided to to change the whole arm over as don’t want to waster money changing bushes and 6 months down the track have to do my ball joints.
I’ve brought some Superpro caster arms and in the middle of swapping them over I’ve discovered that the spacer plates arnt the same.. the ones Superpro provided the hole is drilled off set from centre where the ones fitted the whole is centre..
Am I ok just using the existing ones or do I need to use the new ones??
And is there anything else I need to be aware of , as in position or will that be sorted when I get a alignment??
Thanks in advance..
Thanks in advance..
