Skaa
Just seeing if anyones done a conrod bearing roll in place without any dramas. Had intermittent oil pressure issues and had to replace the pump. Been like that for a while and I'm wanting to inspect bottom end before I sell this car.A $45 set of rod bearings is cheap enuf since I'm there. Sump just seems to be an engine crane lift to clear the pick up. I know the conrod caps are break type halves but seems a straight forward task. I'm not gonna bother with the mains unless the conrod bearings look bad
