Griz
- Apr 14, 2012
- 30
- 0
- 0
- Location
- Erskine Park NSW
- VZ SS 5.7L
Hi guys,
I recently picked up a VE SSV from a dealer. Got a good deal on it & only driven 65000 k's.
It had to have 2 engine mounts replaced and 2 tyres which the dealer took care of before I picked it up. It had no rego, so it had to be blue slipped & this too was taken care of by the dealer. Now the problem. I had a noise in the engine (sounded like a pulley) so I thought I would get the car NRMA checked as it was under warranty & just to make sure there were no other issues.
The inspector came out, spent about 2 hours and found a few troubling issues I want your opinion on.
X![4717600.Standard Vehicles-page-007.jpg 4717600.Standard Vehicles-page-007.jpg](https://forums.justcommodores.com.au/data/attachments/110/110470-0de1874c4bc3e285f6d9bc8bfc6f7373.jpg)
Immediate Repair
Tyres Passenger side rear tyre worn - inner edge worn
Frames and Members Poor quality repairs carried out to front chassis rails. Passenger side front section chassis
damaged & poorly welded. Parts have been "cut out"
E Early Repair
Fluid / Oil Leaks Oil wetness on engine sump pan- front and rear sections
Battery, Charging System Battery tested good although a recharge is advised
Bonnet and Boot
Struts/Locks
Bonnet lifting struts weak
Minor Item
Exterior Trim Inner front mud guard liner on driver side damaged
Upper Body Panels Indentation on bootlid - driver side under spoiler
Other Body Panels Indentations on passenger side front mud guard - above blinker
Wheels Scrapes on alloy wheel rims - all except for driver side rear wheel
Under Floor Panels Lower retaining tangs for rear bumper bar are broken off spare wheel tub
Steering Components Wobble in power steering steering pump pulley when engine running
Do you think this is worth getting fixed or asking for my money back. What kind of cost is involved in fixing the chassis? I have a copy of the vehicle history & there have been no insurance claims (obviously they had no insurance & repaired it themselves) & the mileage is accurate. I am concerned that the chassis was not identified when the engine mounts were replaced or when the blue slip was done. Not only that, missing in the report is the high beam globes were blown & the hand brake does not engage until it is pulled up as far as it goes, 2 things which should have been picked up with the rego check. I am not too concerned about the minor things, but I am getting mixed opinions about the chassis issues. Obviously the dealer is responsible for all costs, but not really the point.
Cheers.
X
Immediate Repair
E Early Repair
Bonnet and Boot
Struts/Locks
Minor Item
Cheers.
