VF S1 redline buzzing noise in speakers
shaklane
50
VF S1 Redline sedan
Hi Team, I'm new to the group, hoping you can help me, please. VF S1 redline sedan recently started getting a buzzing noise through the speakers intermittently. when it's happening, it gets worse when the blinkers are on or breaks are on. any advice or wiring diagram would be greatly appreciated.
stooge
wa
Turbo Alpaca
might be a voltage/alternator issue.
how old is the battery?
tommy_z
35
VFII Director
Try investigating the amp too - faulty one will also cause buzzing at random times.
shaklane
50
VF S1 Redline sedan
Hi mate, thanks for the advice. Battery is just under 2 years. issue only seems to be happening with right side speakers but will run some tests on voltage and alternator as well. thanks again.
shaklane
50
VF S1 Redline sedan
Hi, thanks, will check the connections to the amp and maybe do an upgrade whilst im at it. will let you all know what the root cause was when i find it
XM Pete
53
VF SSV S1 Redline
Hi, Just wondering if you've managed to sort the issue, I have the exact same issue and it's sending us CRAZY!
Skylarking
123
Downunder
Commodore Motorsport Edition
@shaklane hasnt been seen since 19 Sept 2022 and only made 3 posts, all within this thread.
As he hasn't come back to update the thread over the last almopst 10 months, doubt you'd get an answer from him.
