VF series 2 horn wiring diagram
FRIGY
VF COMMODORE STORM WAGON
Hi guys,
I have a VF series 2 redline ss where the horn won't work. I believe its the inbuilt horn relay that is not removable.
Can anybody supply me with a wiring diagram to what colours the wires are going into the fuse box for the horn relay to
trace through and diagnose and to install external relay.
Any other suggestions appreciated
BlackVXGTS
Melbourne, SE
See if this is what you are looking for:
  • Like
Reactions: Lex
chrisp
Melbourne Victoria
VF2 MY16 SS Redline Sportwagon
The circuit diagram posted by @BlackVXGTS provides lots of helpful information. For example, if the relay and wiring might be fine, the issue might be on the other side of the BCM such as the clock spring?
Loupy
64
SA
Vf Calias v series 2
Hi, I am wanting to install the high note horn into my VF II Calais wagon, looking at this diagram, I just need to connect the second horn in parallel to the existing horn, is that correct?
lout
60
Langwarrin Victoria
that is correct
plug should already be there
