Vf2 Ls3 Limp Mode?
Emco
39
Nsw
Vf2 Ssv Redline
Gents
Took ss to Sydney dragway last year just to see, competition mode on and using launch control the car went limp whilst launching
Any body experience something similar with theirs? (dragway or not)
Ron Burgundy
NSW
VF II SS
Gents
Explain all symptoms
Emco
39
Nsw
Vf2 Ssv Redline
On launch in competition mode, the car took then just as It did I thought the car stalled.
I went to turn car on but realised it was still on but pressing acceleration pedal wouldn't even move revs.
I was abit frazzled because I had the helmet on then I put epb on turned car off and started again.
And went down the the quarter
Just the stall like I even thought I snapped the tailshaft or something but it actually went limp it didn't like launch control on the quarter, next 2 runs I did I have everything off and it went fine
MaxCommie689
Donating Member
South-West of Sydney
2016 Calais V
Sounds like something triggered the self preservation mode then. Did the check engine light come on when this happened? And did you try using the launch control again?
07GTS
Australia
VEGTS BUILT BLOWN E85
there are a couple tables in the tune that have to remain in balance and if they go too far out it can cause a cut in power unless disabled, u would have to do it whilst logging to see whats going on
Emco
39
Nsw
Vf2 Ssv Redline
I think check engine came on, I didn't use launch control again after that but since have used launch on the street
MaxCommie689
Donating Member
2016 Calais V
When you originally used launch control, some combination of engine parameters might have crossed safe thresholds programmed into the BCM. Call it idiot proof mode or self preservation mode. It will be very difficult to pin point exactly what went on since you did not log the error codes or other data. If you regularly push the car to the limits (like drags), it might be worth investing in some sort of data logger.
wobbles123
nsw
2008 VE SV6 Auto Ute, 2013 VF SV6 Auto Sedan.
Good on you...well done.....drag session, street launch.....motor expires in a few months!!!!!
