Not_An_Abba_Fan
Exhaust Guru
- Aug 18, 2006
- 14,639
- 1,364
- 113
- Location
- Bunbury, WA
- Strange Rover
When pressure wave tuning, the collector plays a far more important role than the entry angle into the cats. Merge collectors are the best at pressure wave tuning over a longer RPM band, otherwise you will be restricted to a very narrow tuning band with traditional collectors with the only tuning being done by size and length of collector. This would be where the entry into the cat makes a difference, not so much the angle, but the distance from the end of the header pipes to the start of the cat, this is effectively the collector that the engine "sees". My opinion is the use of a merge collector, this negates the need to get the "collector" size perfect. Temperature will affect wave velocity as well, the hotter gas the fast it will travel, exhaust gas can drop by as much as 150 deg C in the length of the primary pipe so ideally, if you want to keep velocity constant, you have to taper the entire primary pipe, but, and it's a big but, (think Nikki Minaj), engine load will vary the temperature as well, so what works at 2500rpm under heavy acceleration will not work as effectively at 3500rpm with light acceleration. Variables, always variables. Optimum exhaust tuning on a street car? When you crack that walnut you will be a very rich man indeed. Since it's never been done in the history of internal combustion engines.
