VG-Vt304
kevingalea
46
central coast
vg ute
hey guys, i have a question i have a 304 vt engine and ive put it into my VG ute with the vg wiring harness, computer and distributer, its not firing the injectors but when i spray start ya bastard down its guts it will breifly fire which means its got spark yeah? it also has fuel pressure. my question is that a vt 304 will run with Vg wiring harness computer and dizzy or?? Thankyou in advance,
H
harrop.senator
Guest
Yes it will as long as the map sensor is hooked up as well. The vt apart from being sequential spark and the air flow meter. I don't think there's any other difference apart from the roller cam and those.
Immortality
Staff member
Sth Auck, NZ
The VT also doesn't have a MAT sensor in the intake manifold runner which you will need.
If you use all the electronics/wiring loom from the VG than it should run. Spark but no fuel can indicate there is an issue with the Dizzy/ignition module. Try swapping out the ignition module and see what happens.
gtrboyy
vt ss & lc gtr
304 vt engine into factory vg 5litre ute or is it conversion?
In theory if you swapped over vn/p dissy,ecu & harness still need hook IAT & map sensor to vt engine.
IAT is in vt airbox & vt 304 intake only has 2 tabs on manifold snout for vacuum lines instead of 3 like vn-s engines.
vt cam will be tad bigger & higher cr but can't see why it won't run on vn/p v8 memcal
