jandjmc
- Jan 2, 2013
- 46
- 4
- 8
- Location
- New Zealand
- VH SL/E 5.0L
I have 2 VH SLEs and it has always bugged that one had some segments missing from the clock display. There are not too many of these still available at the wreckers here in NZ. Finally managed to find one, so bought the clock display. Typical, it also has segments missing. So I decided to pull them apart and have a look. From what I can see they are a display unit only, with all of the processing done in the separate computer under the dash. The display is made up of four separate LED 7 segment displays that are soldered on the board and four buttons. I tried resoldering the pins, but that didn’t work and decided to make one out of the two units. It was a simple process to unsolder one of the working displays on the worst unit, and solder it on the other display. Now I have a fully working display in both cars. I had a look on the internet and it seems that individual LED 7 segment display units seem to still be available, the part number is FND367. If you are not confident to do the soldering, I’m sure a local electronics repairer will be able to do it for you. Hope the info helps.
