Vibration when torque converter locks up
stocky
33
Got a real annoying problem with the VN. When the torque covnerter locks in at 80-100km/h, i get a real bad vibration through the entire car. i thought it was the tailshaft but looks like i was wrong.
i took the old tailshaft out, and the CV joint was absolutely rooted, so i thought i had found the problem. put a new tailshaft in, but the problem remains. what else could cause this vibration?
greenfoam
VP Executive R-spec
How old is the mount?
stocky
33
probably pretty old. will be checking it out tomorrow when i attempt to fix a kickdown cable leak
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
worn out torque converter clutch replace torque converter
stocky
33
ok so far ive replaced the tailshaft and the transmission mount, same problem. would it be the torque converter? i also have 3.45:1 diff gears if that matters. they cause the tcc to lockup earlier than usual
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
i had the same issue it turned out to be a miss fire one of my coils had a crack in it but would only show up wile the car hit overdrive at 80 plus km per hour
having said that ive never heard of my issue causing my problem before but its always worth a look
i will also be looking at doing my converter soon i have 2 good spares :D
HSV99
VT S2 HSV SV99
Definately could be the converter. Had a similar problem with mine. Soon as the converter would lock up if I gave it light throttle just cruising I'd get a brutal noise through the car. Checked the rear end and even replaced a few bits but it ended up being the lock up clutch. Definately worth a look.
CoMrAdE MaRx23
CoMrAdE MaRx23
33
VS Executive 1995
You have obviously checked your engine mounts aswell?
rob drag racer
vn vp drag nut
golden beach
hmm interesting. i have a spare set of coils i can throw on
as i said its worth a try before ya go to the trouble of another converter :thumbsup:
